col41139
After run fan & passenger window issue
I have two issues I like to share and see if anyone out there has had the same problem. The fan stays on after I turn off the car and is draining the battery. The other issue is with the passenger window, it goes down by itself...hello! Any help would be highly appreciated.
First off, which car? My 1.8 16v fan after run switch is a spare off my old golf as the pin snapped on the original. The C switch is a 100 degree switch, whereas the golf is 90 degrees so runs on for longer to cool it down. If yours is a 16v check the pin hasnt broken and earthing out on the head which causes it to run on. with the windows, first off try disconnecting the switches and go from there.
