mattnorgrove
Conlog alarm problem, ideas needed
Morning all, having an issue with the Conlog 900 fitted to my VR6. Both fobs still work fine, both unlock and disarm the alarm/immobiliser, and both lock and activate alarm/immobiliser, and full closure of windows/roof.
The problem I have is that after a couple of minutes once the car has been locked, the alarm goes off, the hazards flash, and the siren sounds (I have discon'd this while I find the problem).
Had a good search through the old posts but can't find anything relevant, so, anyone got any good ideas on where to start looking first?
I have tried a manual reset of the system using the socket type thing under the dash that you can push the fob into, and have tried disconnecting the main battery for a few minutes to try and give it a hard reset, but this hasn't worked either.
Any ideas folks?
Cheers all!
Disconnect the ultra-sonics sensors. They may have become noisey with age.
You will have to follow each cable into the dash and disconnect that that end. Connection is a common type of plug/socket 2 pin if you need to replace the pair. Take them to any alarm specialist and they should have a set that will match connection and fit.
