P3rks
VR6 ABS brake union size - one is larger than the rest?
Does anyone know the size for the male brake union which goes into the VR6 ABS unit, specifically the larger diameter union? - On my ABS unit, the very middle union is larger than the rest but still uses the standard 3/16 pipe.
I believe the standard male brake union size for the Corrado is M10x1 (3/16 pipe).. I believe anyway.
Would I be correct in saying the one larger union is M12x1 (3/16)?
Can anyone confirm please?
That sounds about right , it's very common for a larger fitting to be used here and there
I believe it is m12x1 but I would love it if someone could confirm this as I'm about to start replacing those pipes :)
hi yes it is m12 union.
im selling full sets/singles on the forum, under brake lines remanufactured.
I can supply braided flexis to join it all togeather
It's a m12x1 union for a 3/16 pipe. Confirmed.
Thanks for the offers on the pipes but I'll be using a mishmash of Corrado/Golf/Passat brake/ABS parts so need custom solid lines - I already have braided flexi's.
