mookie
Boot trim missing clips... anyone identify what I need?
The long thin plastic textured trim cover thingy, that covers the lower boot ledge where the latch for the boot lid lock sits, is missing the clips (I assume there should be clips) to attach it to the paintwork. At the moment all that holds it in place is the shape of the metal underneath, and the edge of the rubber boot seal.
Can anyone tell me what I should have pop through those round holes? :scratch:
Cheers! :smug:
Mate there is 6 round plastic plugs that hold it in also there is a square plug on the top that the boot popper hits
not sure on part number but prob have some will take a look in the the stock room tomoz unless you want to just buy new sure will only be pennies
I did wonder about the square one! Yeah if you can dig them out that would be mint, as much as anything just so I can see what they look like.
lilfuzzer: Are you talking about these things? http://cl.ly/391j2y1n0Z3f0Q3f3c2f
If so, I'd be after some too - just taken the trim off mine to see why the plastic the number plate mounts to keeps coming loose (it's because it's not screwed in - at all! What should be hold it on to the metalwork?) and they're all destroyed, presumably by a previous owner thinking you have to unscrew them completely, rather than giving them a quarter turn. Haven't had any luck with Google finding them this evening!
