carrots
changing inner cv boots
hi my inner cv boots are split.how hard is it to change them and what tools do i need.1990 1.8 16v cheers
spline socket for the driveshaft bolts is about all you need, that and plenty of rags for the horrid cv grease
iirc the inners just slide off the shaft left on the car once the bolts are all off and the joint falls away from the gearbox flange, if they need a tap to pop them off it shouldn't be difficult to do on the car
so its not to tricky then.ive got new bolts with the boot kits and i will put some thread lock on um
hi do you know what size spline socket i need.my new boot kit comes with allen key bolts
