imyhamid
quick question about electric Recaro's
Hi all just wondered if someone can point me in the right direction, I have been given a set of electric recaros from a corrado and want to fit them in my VR. The question is how do i go about connecting up the seats so they work electrically??? I'm not the best with electrics so if someone can give me some sort of wiring diagram i can follow that would be great.
Cheers, Imran
cheers mate, that guide is perfect. Does anyone know the part number for the connector to go into the fuse box???.
Cheers, imran
I'll try to dig out the part number from when I ordered mine (I'm at work at the moment). But I've attached a (blurry!) picture here in case that helps:
[ATTACH=CONFIG]68322[/ATTACH]
A 35amp female spade connector with a plastic or rubber insulator and an inline fuse connector is what you need bud.
I'm afraid I couldn't find the part number for the connector. I have so many invoices for "casing" and "connector" that it's impossible to tell from my pile. A spade connector should work but personally I prefer a proper connector.
I made this up for the live connection to include the inline fuse:
[ATTACH=CONFIG]68329[/ATTACH]
Sorry to resurrect this - but did anypne ever find a part# for the red single pin connector in the pictures ?
resurrect this? its only a day old!
