Justin Bolton
Mk3 gti braking?
Does anyone no what is needed to to put mk3 golf gti brakes etc on a 2l corrado as I wanna go up to 5 stud but can't afford the mk4 set up please help all advise will be great full
Bit confused with what you are after, are you going 5 stud or staying 4 stud?
If its 4 stud you are after, you can use corrado vr6/early golf gti/vr6 or G60 brake calipers, they are all 280mm but you will need G60 4 stud brake discs. They should all be straight bolt on and you can use the same hoses.
cant afford the mk4 setup ? the rear calipers are so cheap its almost stupid not to, just to confirm you are wanting mk3 brakes along with changeing your stud pattern from 4x100 to 5x100? which means buying new wheels to suit that,
Well the thing was I have a mate breaking a mk3 gti so I wll be able to get wheels and everything else I need with ease just not sure what was needed drive shafts etc ?
