nipper09
first summer drive
hi again all
i know i seem to have a lot of questions but i will settle down soon and start helping others with my answers
just been for a ride to mumbles about 10miles either way
its very warm outside and there was a lot of traffic so sometimes i was crawling and sometimes i was motoring:dance:
my questions are
1. my water temp whilst crawling creeps above 110deg.
2. its about 105 109 deg. when iam motoring. are these normal temps?
3. the tunnel where your feet goes is boiling!!
4. should the front drivers side wheel bearing nut have a grease cap? if so where can i get 1? is it compatible with other models?
5. are there any jobs maintenance wise i should be doing for prevention? ive just noticed a "how to lube your rear spoiler on coc uk "
just for info i have a storm with 94k no water leaks and just fixed my oil leak ( rocker gasket ) ive got semi synthetic 10w 40 oil in her.
cheers in advance paul
Edited by nipper09
1 that's too high
2 again no not normal too high
3 are the hot vents directed there?
4 no the bearing is internal, only caps on the rear
Get reading the definitive vr6 cooling thread for solutions and preventative measures!
