ausgolfer 0 Posted August 21, 2012 (edited) Hi all, Have a 92 G60. Really want a VR6 but they're non existent in Aus..... Willing to do a conversion, but seeing as there's no corrado VR6's as donor cars here I could.... A. Spend a lot to import a whole car or a whole bunch of parts from a Corrado VR6 to do the conversion. (not legal to simply import and register a VR6, it needs to be as a "race car only", or literally cut in half) B. Buy a Golf 3 VR6(relatively cheap and importantly available), use that for conversion...yes I know it'd only be a 2.8 but could always upgrade that later. At least I'd have similar hubs/driveshafts/suspension arms as a VR6 Corrado. C. Buy a Bora Sport 24v.....more expensive....use that for conversion (probably doesn't have the same VR6 intake roar I want). D. Other? cheers. Share your thoughts and oppinions. Read to the bottom please, have a follow up query regarding VR6 passat bits. :) Edited March 25, 2013 by ausgolfer Quote Share this post Link to post Share on other sites
Craig 0 Posted August 21, 2012 Sounds to me like b would be your best bet. If you import a 2.9 manifold and put some cams in the 2.8 golf you'll find there is little difference between the two anyway. where is aus? austria? Quote Share this post Link to post Share on other sites
Stonejag 10 Posted August 21, 2012 There are tons of VR6es in Germany and Austria, my money's on Australia ;) If you get an ODB2 Golf it'll be much more efficient than the 2.9 anyway, and the better engine management means they can run with more ignition advance so it'll still be quick! Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted August 21, 2012 Definately going with Australia. Id say B also, its the easiest and cheapest way to go and its more or less the same as the 2.9 and you have OBDII. Is a Corrado really worth the money and hassle to import when it would have to be a "race car" or damaged beyond repair. I know you'd only want the engine and drive train, but to go to all the effort and money for a broken car isnt something id recommend. My vote is B. :D Quote Share this post Link to post Share on other sites
ausgolfer 0 Posted August 21, 2012 thanks guys, good advice and good guess with Australia too ;) Quote Share this post Link to post Share on other sites
ausgolfer 0 Posted August 22, 2012 As a follow up query. Would a passat VR6 be a slightly better donor than a golf VR? Roughly the same value here though the passats are rarer. Quote Share this post Link to post Share on other sites
ausgolfer 0 Posted March 25, 2013 (edited) Old one, but a bump as an OBD2 96 passat VR6 has popped up in my area cheap..... Would the control arms and rear beam of a passat VR6 be an ok fit Vs std VR6 golf 3 parts? Edited March 25, 2013 by ausgolfer Quote Share this post Link to post Share on other sites
destructiv dave 0 Posted March 25, 2013 Old one, but a bump as an OBD2 96 passat VR6 has popped up in my area cheap..... Would the control arms and rear beam of a passat VR6 be an ok fit Vs std VR6 golf 3 parts? Front end parts will be fine. For the rear, I'm going to say yes although I have seen posts somewhere where it lists all the different rear beam part numbers and possibly any subtle differences so could be worth checking for this (may be on ClubGTI forum). However if there are issues with the rear beam fitting, then you can just change the rear hubs to 5 stud on the beam you already have. Quote Share this post Link to post Share on other sites
