Big_Al
How the hell do you get the 3 piece windscreen scuttle off?
Hey guys,
I noticed the other day that my car was starting to sprout little green leaves from under the right hand side of the scuttle.
So I tried to remove said plastics to clean out under it.
I removed both wiper arms and removed the screw holding the drive side panel in place and expected the thing to lift away. How wrong was I......
I gave it a little more effort and it started to lift but seemed to be very well stuck down around the middle of this little piece. I felt underneather for bolts, couldnt feel any.
It doesnt appear to be stuck to the windshield itself as I can, with much pain to myself, get my fingers under it.
I feel that I may have broken a clip or something as the plastic will no longer snap back flush to the glass as it was before. :(
Any advice on how to remove this would be welcome as I feel having a tree growing out of the front of the car may harm the mpg :)
Cheers.
Al.
It sounds like some dubious windscreen fitter has stuck it down with mastic ! It should be just clipped down onto these
You will have to be careful getting it off,maybe a thin razor wire under it ! Be warned,the three parts are now obsolete !
I take it the clips are still available?
I was sort of thinking of going down the spoonfedtuning route of a new one piece scuttle in time, but really cant afford to do it right now :(
Not sure if I want to try this now, knowing how my luck goes with this sort of thing :(
Cheers.
Al.
