nipper09 10 Posted August 25, 2012 hi all the problem ive got is when iam braking at high speeds the steering wheel shakes like buggery!! is this brake discs? if so whats the best ones to get its a standard storm at the moment cheers paul Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted August 25, 2012 Certainly sounds like warped discs. If running std size ones then either VW or perhaps Pagids from GSF. Might be worth considering the upgrade to Mk3/4 Golf type 288mm fronts as it is supposed to make quite a difference as it is a much larger pad surface area? Ian. Quote Share this post Link to post Share on other sites
anne t 10 Posted August 25, 2012 i had this and it was the discs had warped,but was also told it could have been worn tie rods replaced with oem spec discs+mintex pads done the job Hopethis helps Quote Share this post Link to post Share on other sites
