clintuk1978 0 Posted August 25, 2012 Has anyone got the plastic part of the roof trim that covers the outer boot hinge on the passanger side? Little square plastic part. Thanks Quote Share this post Link to post Share on other sites
rodmax 0 Posted August 25, 2012 Hi I do have one ,will confirm which side it is,will get back to you Rod Quote Share this post Link to post Share on other sites
daves16v 1 Posted August 26, 2012 Think I've got both if you get stuck. ---------- Post added at 6:14 PM ---------- Previous post was at 6:08 PM ---------- By the way, how do these come off? Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted August 26, 2012 Think I've got both if you get stuck. ---------- Post added at 6:14 PM ---------- Previous post was at 6:08 PM ---------- By the way, how do these come off? Carefully! They have 2 plastic pins attached, they just push on Quote Share this post Link to post Share on other sites
daves16v 1 Posted August 26, 2012 Got both of them off tonight, not matter how careful I was one pin broke on each. Quote Share this post Link to post Share on other sites
clintuk1978 0 Posted August 30, 2012 I have no idea how mine came off? Rod, did you find out what side you had? Thanks Clint Quote Share this post Link to post Share on other sites
KIPVW 0 Posted August 30, 2012 Best way of removal is to raise the hatch, squirt a little WD40 on the pins and then push the pegs carefully with a biro or pencil that's the same size, less chance of breaking them this way. Quote Share this post Link to post Share on other sites
VWVW 1 Posted August 30, 2012 Got both of them off tonight, not matter how careful I was one pin broke on each. They will still be usable if you use double sided number plate tapes or similar tapes to hold them down. I broke one of mine before and its still held in securely after 2 years with tape. Quote Share this post Link to post Share on other sites
clintuk1978 0 Posted August 30, 2012 Well Im still looking for one if anyone has one? Quote Share this post Link to post Share on other sites
