Yandards
G60 BBM Boost Pipework
I have a set of G60 BBM brand metal boost pipework, this has 2 extra joins where I cut a section off to accomodate my charge cooling setup but I am supplying a section of silicon hose to join the pipework back up - the join will be located out of sight as it is down towards the intercooler.
For those that don't know anything about this set of pipes it is still available from BBM link here
You will need an RSR outlet kit of similar to be able to use this set of pipes and I have resprayed mine in satin black to make them look more OE in the engine bay, this is a very well made and solid set of boost pipes that don't leak like the plastic ones and as an added bonus you will be able to fit the gearshift weight which massively improves the feel of the gear shift operation.
There are some scratches and marks on the paintwork as would be expected of a set of tubes that have done around 20k but there is only one small patch of rust that will need a little bit of treatment.
I am including a brand new set of jubilee clips to make the fitting easy as the old ones were a bit tired.
This kit will cost you over £250 new from BBM before shipping and import duty, I am asking for £100 plus postage (should be around the £10-15 mark).
[ATTACH=CONFIG]69217[/ATTACH]
If ur open to offers I would like them but only could afford £70 plus postage let me know cheers dude
