Ad's 16v
120,000 Mile Service
Okay just got back from the stealers after picking up the C from her 120,000 mile service.
So here's a list of the problems, (thank god far less than expected and not to difficult to rectify.
New Front Tyres Required
NSF lower ball joint worn
Rear axle bushes worn
Rear Bump stops broken
OSF ABS sensor Required
I'm happy with that :)
Did they tell you how much it costs to do the rear axle bushes?? Bit pricey!
Rear bump stop replacement requires stripping the struts down too - you may aswell put new shocks in while you're having that done. (120k is not a bad life for a shock, plus they'll only cost about £30 each + VAT, which will be less than the fitting cost..)
When i get around to it mat i'm going to put a set of Koni coilovers on there, after hearing almost everyone on the forum rave on about how good they are oh yeh and some powerflex bump stops and bushes. :D
