nickeboy 0 Posted September 26, 2012 After hearing divided opinion on the rear beam with many saying the part numbers are the same on all models i checked it out a VW today. They are not the same the VR6 (abv) Has its own part number (1HQ 500 051 Q) the other models are 191 500 051 with either J, M, or L at the end for different engine codes. The VR6 one also mentions 20mm in the remark column which i assume relates to the wider track i hear about. Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 26, 2012 Not seen them side by side but I imagine the beam is different where the bushes fit as the bushes are different to the 4 cylinder cars Quote Share this post Link to post Share on other sites
dragon green 5 Posted September 26, 2012 The bracketery that holds thei brake proportioning valves are different on the four/six pot cars ! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 26, 2012 Yep - it's completely different as the VR uses Plus Suspension with a wider track Quote Share this post Link to post Share on other sites
