wapadrand
Original rear speaker connectors
When I bought my Corrado many years ago, someone had put speakers on the rear parcel shelf. Have never liked them, and removed them over the weekend. Now want to connect the original rear speakers back up.
Found the original connectors (191906231-A, flat contact housing) plugged into the speakers - the wires had just been cut off.
Not obvious, but does anyone know if there is any way to re-use these, or are replacements available?
Thanks.
Edited by wapadrand
You should be able to just solder the wire directly on to the old speaker contacts. It would only become an issue if you need to remove them again in future obviously, but will have no detrimental affect on the speaker itself.
