STORM 2
switched live in boot area?
Anyone know where I can find a switched live in the boot area? [for an amplified aerial]
cheers
A few options ........
1) Lift the black cover on the boot floor and tap into the fuel pump 12 volts supply on the Red with yellow stripe wire. Fuel Pump relay controls supply.
2) Behind the left side rear passenger side card there are the heated seat relays. Tap into the Black wire with Yellow stripe. Fuse 14, 10 amps controls.
3) Behind the right side rear passenger side card there is the window lift controller, try the black wire to it. Fuse 14, 10 amp controls.
Edited by RW1
you ARE the man OBI-RW1
