mr lobitos
failed mot on no highbeam
just failed test on no high beam
lights are working fine but as soon as you switch on highbeam, lights go down to sidelights
tried new bulbs , no joy
had a quick search on here but no defo answers
noticed two relays with 52 on them down by the battery ,are these to do with an uprated lighting loom
any ideas ,thanks for looking
Yeah id say its to do with your uprated headlight loom maybe a stuck relay. Put the origonal plugs back in if your in a hurry to get it through the mot
Sent from my GT-I9100 using Tapatalk 2
Exactly what happened with mine. I drove home took the wiring loom off and it sailed through.
excuse my ignorance but what do i need to do, replace the relays or go back to the old loom , will that still be in place :scratch:
Do either depending on your time frame, and yeah the original loom should still be there the uprated loom plugs into it
The uprated headlight looms, ahhhhhhh the problems, the thing is there arent any relays in the engine bay and thats for a reason, if you open a relay up and how small the contacts are, so any moisture that gets into them and ruins the relay.
They should be in a sealed container, or in the cabin of the car.
