Corradochris16v 10 Posted October 20, 2012 Can Anyone help my reg plate lights arnt working I've changed the bulbs and checked the fuse the only thing I haven't done is check the lights with engine running as me engine is in bits would this make a difference? Quote Share this post Link to post Share on other sites
dragon green 4 Posted October 20, 2012 Take the light out,the wires on the unit are soldered on it. Not very well ! Or mine wasn't ! Most likely it needs re-soldering. If wires are ok,check with multi-meter Good luck Quote Share this post Link to post Share on other sites
Corradochris16v 10 Posted October 20, 2012 Ok cheers mate ill try both Quote Share this post Link to post Share on other sites
tom91 10 Posted July 18, 2013 Ive got the same problem but ive got low voltage going to them not 12v :/ anyone else had this issue ? it was after i changed my rear spoiler aswell Quote Share this post Link to post Share on other sites
Portent 0 Posted July 20, 2013 Take the light out,the wires on the unit are soldered on it. Not very well ! Or mine wasn't ! Most likely it needs re-soldering. If wires are ok,check with multi-meter Good luck I had this exact issue on mine. Simple to fix. Just unscrew the light cover and solder the wires back on. Quote Share this post Link to post Share on other sites
