chrishill
random beeping???
this happened three times today, each time while doing a hard right at speed, twice while on roundabouts once while turning into a junction. I get this little 'beep beep beep' noise thats very simular to the sound the imobiliser makes when it arms, but louder. Its only started happening today, theres no warning lights on the dash, oil temp looks fine....i'm really confused! :?
  VR6 said:
Sounds like oil warning light.
yip i would agree with VR6.....best check your oil level 1st.....tho more than likely it will be the switch thats the culprit
More than likely it's just because you're flinging it into corners that's causing the oil to collect at one side of the engine.
Not doing it any good if it's not picking any up in the process though....
