Riclad
MFA
I bought a 1.8 16v around 6 months ago. Eversince, my MFA indicator isn't working properly. It's stuck on MFA 2. Is there a way i can reset it completley, or anything else. Or, do i just need a new one, if so, where do i get one from?
You could try disconnecting the battery but it sounds like the switch on the stalk is shagged, new ones from GSF, same as mk2/3 golfs i think depending on the year of your car.
can you switch between the different modes on MFA2? if that doesn't work either, there's a multiplug under the steering cowling that's probably come adrift! ;)
I just ordered one from VW £54.The guy on the phone said the was two different ones for the 1.8 16v depending on your chassis number-dont know the reason for this.
Cheers Fraser
