Hofmiester 10 Posted December 9, 2012 Trying to remove the upper part of the cowl tonight so I can epoxy the screw holes so it all fits together properly again. I can't get the thing off due to the steer column adjustment lever. I have given the lever a little pull to see if it will come off easy but not shifting.....how do I get it off? Quote Share this post Link to post Share on other sites
dumptyboy 0 Posted December 9, 2012 you need to remove the 10mm bolt that connects the arm through the cowling! The bolt is in quite an obvious place under the adjuster lever. :) Quote Share this post Link to post Share on other sites
dragon green 6 Posted December 9, 2012 IIRC there's a 10mm bolt you have to undo to get adjuster out ! Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted December 9, 2012 Haha, awesome. I'm working with just the interior courtesy light.....that area is all in shadow! Quote Share this post Link to post Share on other sites
Stonejag 10 Posted December 11, 2012 FYI - it's much easier if you undo the 10mm bolt and then remove the upper cowling with the outer part of the arm still poking through it. The outer bit of the arm is removed from the upper cowling by pushing it inwards and rotating it 90º, so if you remove the cowling first you can see what you're doing and won't snap the slot by mistake :) Stone Quote Share this post Link to post Share on other sites
