clumpy1
Spoiler lubrication
Where are you intending on lubricating? If you are referring to the two main black sleeves and sliding supporting arms, then these do not need lubricating (and if anything other than a dry lubricant, will attract unwanted dirt etc - best to avoid). The spoiler tubes and cables within - a liberal spray of white lithium grease or similar will be fine. As far as 'proper', not sure there is a particular one - many choices.
I took my whole assembly apart using the WIKI on here, cleaned the assembly up and used a bearing grease. It's been fine since then.
