OllieVR6 0 Posted January 5, 2013 When I unlock my Clio (from the remote) the interior light comes on. It stays on for 30 seconds or so and then fades out. You can get boxes that will provide the fade out functionality on the internet, the bit I want is the 'on with unlock'. I have a right click keyless kit installed so I would imagine I can tap into the unlock signal from that, but that's about as much as I can work out. Would it be a relay to the interior light to make it come on? Really wishing I had paid more attention in electronics class now! Quote Share this post Link to post Share on other sites
Anton Sobriquet 0 Posted January 5, 2013 Doesn't the interior light come on when you open a door anyway? Why do you need it to come on before? Just asking... Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted January 5, 2013 Because where I live there are no lights in the car park and I find with the Clio the interior light is enough to highlight any puddles to avoid whilst walking to the car :) Quote Share this post Link to post Share on other sites
Anton Sobriquet 0 Posted January 5, 2013 Maybe a torch would be easier Ollie... LOL Quote Share this post Link to post Share on other sites
mad-dog 10 Posted January 5, 2013 if i hit unlock on mine the light comes on for about thirty seconds ??have you got it switched on to on ope3ning the doors as i think this helps? Quote Share this post Link to post Share on other sites
KipVR 1 Posted January 5, 2013 Perhaps install follow me home headlight kit? Then you will see the road better. Works unlocking too! Quote Share this post Link to post Share on other sites
james153 0 Posted January 7, 2013 you need a timer delay relay, available off ebay for about £8.00 just feed a permanent live and earth through like you would a normal relay and then splice into your unlock signal wire as the activation feed for the relay, might need to put a diode in to prevent any additional resistance that might be generated from interfering with your locking system, however I wouldn't have thought that this would be an issue. Hope this helps. Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted January 8, 2013 james153 said: you need a timer delay relay, available off ebay for about £8.00 just feed a permanent live and earth through like you would a normal relay and then splice into your unlock signal wire as the activation feed for the relay, might need to put a diode in to prevent any additional resistance that might be generated from interfering with your locking system, however I wouldn't have thought that this would be an issue. Hope this helps. Like this? http://www.ebay.co.uk/itm/MINI-SMD-TIMER-SWITCH-TIME-RELAY-1-TO-145-SEC-KIT-10A-Delay-Off-Switch-12V-/280819762656?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item41622985e0 Quote Share this post Link to post Share on other sites
james153 0 Posted January 8, 2013 Yes that looks good, or possibly this; http://www.ebay.co.uk/itm/230707639704?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 the best way to do it would be to have an earth into the relay and then feed the output from the relay into the normal earthing circuit for the interior lights. or could go along the route of positives, depends what you prefer. Quote Share this post Link to post Share on other sites
KipVR 1 Posted January 9, 2013 Surely this is better than using an interior light to guide your way? I have this function on my Mk5 golf and I use it all the time at home as I have to park where there is no outside light... http://www.ebay.co.uk/itm/Univers-Coming-Leaving-Home-Module-Relais-Headlight-Light-Delay-Sensor-Head-Lamp-/221122875094?pt=UK_Other_Clothing_Protection&var=&hash=item337bf34ed6 Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted January 10, 2013 Cheers Kip that looks like just the ticket. When you mentioned this before I didn't realise you could buy it like that. Think I'll make an investment and give it a try. Quote Share this post Link to post Share on other sites
KipVR 1 Posted January 10, 2013 Glad to help Ollie! Hope it fits the bill Quote Share this post Link to post Share on other sites
