maff
92 vr drivers footwell leak
well theres no space to push the seals out so i resorted to using some neoprene sealing tape. Now the problem is this is quite hard to compress so the door needs a good hard slam to close! Dont want to loosen the lock pins else i'll be back to square one again. It may compress a bit over time though, lets see. It does suggest however that the seal create at the lock side is pretty good, its just this bit in the middle - maybe the door had bowed?
