Jochen744 10 Posted January 28, 2013 Hi All, I have had my Corrado off the road for 28 days now and I think it now has the hump!! I went to unlock it to put some bits in it and the passenger door will not unlock, the button try's to go up then goes back down, I can not pull it up from inside as it just pulls back down. It seems it is dead locked shut, I am thinking the lock unit must have seized. and I will try disconnecting the pump and try to pull the button up then next weekend. Has any other people had similar issues? and how did you get it open? Thanks, Jochen.:scratch: Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted January 29, 2013 I had this issue and found it to be the lever part inside door needing greasing. Might not always be that but solved my problem. I had to reach inside the door from the gap between window and door frame and pull a lever up. ---------- Post added at 9:47 AM ---------- Previous post was at 9:45 AM ---------- Bit weird photos but this is the bit i had to pull upwards and with door shut and window half open i got to it from here Quote Share this post Link to post Share on other sites
