bully
anybody fitted an amp in there car? and get bad feedback on start up?
i get a constant pulsing threw my amp when u start it up.
i was told i need a surpressor.. but havent a clue what one is or what kind i need to buy.
has anyone had this issue and how did they fix it ? did you buy a surpressor and what one please help
When you ran your cables did you run the power for the amp down 1 side of the car & then your speaker cables down the other?
It can cause inteference if you run them close together
yeh they seperate.. had a auto electrician check it out its fine.. just he said that corrados are an old car and run a high voltage
Glad all is electronically ok.
I recall on an install in a previous car where i had lots of engine noise through the sub i fitted a small & IIRC cheap crossover as the can help reduce the interference - it worked a treat & having read this thread i really should fit 1 to my rado lol
I get a bit of a pulse through the speakers when I start it up but it is only very brief and only once each time. I just live with it to be honest as I don't think it will do the speakers any harm as it is nothing they dont handle on a constant basis anyway. I'm presuming if the voltage wouldn't be too high to damage the amp in any way as if it was it'd simply blow one of the many fuses.
