welshside 10 Posted February 18, 2013 I've currently got an aftermarket 2 slat grill with eyebrow which is faded grey and doesn't look the best. I bought a nice 3 slat grill with badge on ebay off a 90 16v and thought it would fit straight on to my 91 g60. VW dont make life that easy though because the bottom tabs are in the wrong place. That doesn't seem to much of a problem though, reading about on here people have cut the bottom tabs off and re-glued them to fit in the bumper slots. Before I butcher a perfectly good grill can someone confirm the top tabs will line up because I haven't seen any threads mentioning them, and will the grill line up fine? Quote Share this post Link to post Share on other sites
16VG60 1 Posted February 18, 2013 I have adapted my own late grille to fit early front panel and can confirm the top tabs do line up without modification. Quote Share this post Link to post Share on other sites
welshside 10 Posted February 18, 2013 Thanks, I'll see if I can move the bottom tabs on the weekend without glueing my hands to the grill. Quote Share this post Link to post Share on other sites
Dec 1 Posted February 18, 2013 The other problem with fitting the late grille to an early spec car is that it wont sit flush with the headlights without a fair bit of modification. I ended up relocating the lower tabs and then taking about 5mm off the whole inner/radiator side of the grille to make it fit flush. Quote Share this post Link to post Share on other sites
welshside 10 Posted February 18, 2013 It's never straightforward and simple when working with corrados. I'll chop off the tabs, see how it's going to fit, then go from there. Thanks Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 18, 2013 Either fit late headlights as well or keep the original grille, anything else is a bodge. Quote Share this post Link to post Share on other sites
