woody
problem with wiring inpro lights
Ok what i have is on each light there are some wires from the bulbs
These are 5 wires :
Black & White x 2
Green & Yellow
Green & Red
Green
Now on the connector which need to be cut off there are on the offside :
Brown
Black & Red
Black & Grey
Black & White
And on the on the nearside there are :
Brown x 2
Black & Red x 2
Black & Grey
Black & green
Could someone expalin which wire goes where please ?
You put blue spades on the end of each inpro wire and then slot them into the VW plug. Brown on the VW wiring is earth, then you can work out what the rest are easily enough by put the hazards and side lights on and sampling the connections until you get it. The last one is obviously therefore the brake light.
HTH
K
Right: As Kev already mentioned don't cut anything from your Rado wiring loom (leave the Rado connector where it is), just stick on some blue spade connectors onto the In.Pro wires, then following the table below connect the lot:
Function: Rado-wire In.Pro wire
rear light left grey/black green
brake light left black/red green/red
indicator left black/white green/yellow
earth brown white/black
rear light right grey/red green
brake light right black/red green/red
indicator right black/green green/yellow
HTH,
Tempest
Might be worth moving this to common questions as more and more C owner are changing their lights to after market ones.
I hope not, as it would make those that have converted less unique :lol:
Tempest
