mike_303
68mm pulley advice
Only a quick one, Ive got a pulley and a jabba chip but was wondering if I need to run a shorter belt if I have the tensioner extension or if its one or the other?
Cheers
6PK1640 this is the belt you need as i was advised on another site n i have it on mine!
type it in on ebay there only about £12 from gsf on there
Tensioner extension? Do you mean the modded adjustable ones from the likes of jabba?
As long as the belt twists roughly 90deg then you are ok. Best with the shorter belt as above really, and if you do have an adjustable tensioner just tweak the tension until it feels right (90deg)
Neil.
Edited by Riley
Spellingz
if u can twist the belt itself by 90 degrees n no more then the tension is perfect, any more n its to loose n less than 90 its to tight!
hope this helps
hope this helps
Ah gotcha, makes perfect sense to me now! cheers everyone.
