bigbaz 10 Posted March 3, 2013 hi can anyone tell me what this sensor is please the 1 that is threaded in by the fuel pressure reg as the wire has broke of it[ATTACH=CONFIG]72673[/ATTACH] Quote Share this post Link to post Share on other sites
owen g60 10 Posted March 3, 2013 It's a temp sender if sorts. Linked to the after run fans I believe. Quote Share this post Link to post Share on other sites
bigbaz 10 Posted March 3, 2013 ok cheers for that not a problem then Quote Share this post Link to post Share on other sites
Yandards 0 Posted March 3, 2013 bigbaz said: ok cheers for that not a problem then That depends on if you want your G60 to work or not. All the early Corrado engines have a similar sensor used for coolant fan run on, they also run the fuel pump on the G60 to prevent fuel vapourisation issues as well. So I would recommend you have one or your coolant fan won't run when you turn the car off. Quote Share this post Link to post Share on other sites
bigbaz 10 Posted March 3, 2013 Yandards said: That depends on if you want your G60 to work or not. All the early Corrado engines have a similar sensor used for coolant fan run on, they also run the fuel pump on the G60 to prevent fuel vapourisation issues as well. So I would recommend you have one or your coolant fan won't run when you turn the car off. Cheers where's best to get one from Quote Share this post Link to post Share on other sites
