EvilZak
Door Lock/Unlock Problems
Has it been a bit dodgy leading up to the point of complete failure?? Even with power failure (which is what happened to me) you can still open the door with the key. Obviously the rest of the doors dont open.
Got any more symptons or info? I take it that the lock mechanism does turn when you try to lock/unlock?
cheers
timo
The CL switch lead from the drivers side handle has probably perished, when I changed my door handle when it broke, the switch wires literally fell off as I removed the handle!
