n8047035
no beep
when i first got my corrado, it used to beep twice when arming the alarm and just once when dis-arming it. Im not sure what kind it is, although it definately is a CAT1. Anyway, for some reason, ive lost the beeps although the actual alarm and central locking still works. ive got the feeling that this means that only my lights will flash if the alarm goes off. What could be wrong?
Try it and see. Sit in the car, set your alarm, then move about and see if it goes off. You may have just set the silent arming/disarming feature most alarms have.
it sounds like my toad alarm...what does the key fob look like?? green is it?
theres a way of doing SILENT arming or disarming so i'm sure you can turn it back on with the right button combination pressing.
i think on my toad its buttons bottom left first THEN press top left to arm...but i'd have to check later as i'm at work.
Goodluck mate.
Sanjay.
