timthetinyhorse 0 Posted March 29, 2013 Just been having a look on vagcat and I notice I need a support bar to fit the splitter, is this still available from the dealer? Also I see I need two different types of bolt and a sort of nut clip, can anyone tell me how many of each item I need. I can see the part numbers so just need amounts. Cheers Rob Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted March 29, 2013 Hi Rob, The support bar was certainly available a couple of weeks ago as I replaced mine when I changed to a 50mm splitter. From memory there are 5 bolts that hold the splitter on thru' the support bar and then 2 bolts and nut clips either side as well (So 4 off each in total). Ian. Quote Share this post Link to post Share on other sites
bmwcompact 10 Posted March 29, 2013 As above part nos: Reinforcement bar: 535 807 181 plus 5 shouldered bolts: N 904 338 01 N 010 473 01 speed nut and N 015 946 1 panel screw. Splitter has holes for 3 each side, mine only had 2 each side fitted: Its your choice! (Info for those reading this post who want part nos) Quote Share this post Link to post Share on other sites
timthetinyhorse 0 Posted March 29, 2013 Thanks very helpful Quote Share this post Link to post Share on other sites
