timthetinyhorse
Splitter fitting
Just been having a look on vagcat and I notice I need a support bar to fit the splitter, is this still available from the dealer?
Also I see I need two different types of bolt and a sort of nut clip, can anyone tell me how many of each item I need.
I can see the part numbers so just need amounts.
Rob
Hi Rob,
The support bar was certainly available a couple of weeks ago as I replaced mine when I changed to a 50mm splitter. From memory there are 5 bolts that hold the splitter on thru' the support bar and then 2 bolts and nut clips either side as well (So 4 off each in total).
Ian.
As above part nos:
Reinforcement bar: 535 807 181 plus 5 shouldered bolts: N 904 338 01
N 010 473 01 speed nut and N 015 946 1 panel screw. Splitter has holes for 3 each side, mine only had 2 each side fitted: Its your choice!
(Info for those reading this post who want part nos)
