edd 0 Posted April 7, 2013 Blast.draft.b0ll0ks. So despite the car having virtually no rust anywhere else I discovered a horribly rotten battery tray this weekend. Was a complete tray before i put the screwdriver through it but within minutes id pulled it back to the solid stuff which left me with this... Having looked on ETKA it looks as though the battery tray is a welded in section thta would just about remove the whole of the rotten area but i cant be sure if the inner wing is affected to. looking at the join line i think not, can anyone advise... Is the battery tray still available i have looked on VW Heritage and vw classic parts De and i cannot find it? otherwise is it a case of finding someone murdering their own Corrado and cutting the necessary body parts out? part 14 on the exploded diagram i think Edd Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted April 7, 2013 Doubtful the tray is still available but costs nothing to find out. Best bet is to get it off a breaker... OR jsut get someone to fabricate a piece and get it welded in. Just make sure to remove any rust to prevent it returning. Quote Share this post Link to post Share on other sites
vw rule 19 Posted April 25, 2013 Hello ladies and gents, I wounder if you could please advise me if I'm correct or not. This battery tray issue for the Corrado am I correct in saying that it's the same or very similar to that of a MK2 Golf, as the Golf panel can be purchased for £26.50 Many thanks. Si Quote Share this post Link to post Share on other sites
matty golf 0 Posted April 26, 2013 Hi mate just done mine last week battery tray is available on classic parts about 90 quid plus postage. Put a wanted add up mate some 1mightbe braking one Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted April 26, 2013 my advice is remove the front end {not even a 30min job} and cut the rott back sqaure in a nice rectangle shape with a cutting disc on a dremel, and cut a peice out from an old door or bonnet to put in its place maybe try and shape it if it needs it , weld it up and wax oil the crap out of the back side of it, you could buy a cheap welder , before you say " i cant weld" if you can draw then you can weld ,its just like dot to dot or if you want to spend the extra money and time on finding a genuine tray then go ahead but if it was me i idd rather splash out the funds on something that will get noticed/make a difference.. Quote Share this post Link to post Share on other sites
edd 0 Posted April 27, 2013 Interesting thanks chaps, just how close is the mk2 one to the Corrado?, mine has rotten to the right hand edge wall of the tray looking from the front of the car so ideally I want the whole tray panel as if would come if it were a Corrado replacement (if you get my drift, the vertical edge of the tray provides the welding point to the inner wing I think) Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted April 27, 2013 I would go one step further than wax oil, use POR 15 on it. That stuff is beyond hardcore paint. Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted April 28, 2013 the reason idd use wax oil under the tray is becuase you can spray it with a long flexy hose and it penetrates into all the nooks and crannys that you cant actualy get to, it will also neutralise current rust , from what iv read about por 15 its good to use on metal thats been cleaned up from rust and forms a very hard durable coating so its perfect for painting the top of the battery tray but if you still have rust and moisture under the por15 then its still going to carry on rusting under it, i guess everything has its pros and cons, Quote Share this post Link to post Share on other sites
vw rule 19 Posted May 2, 2013 Cheers guys for all the info :thumbleft: I've just purchased a welder so will be replacing the battery tray at the weekend. Plus will fabricate up a new replacement air intake duct as mine has rusted out, this is the air duct scoop under the radiator that draws air in to it. Cheers, Si :thumbleft: Quote Share this post Link to post Share on other sites
edd 0 Posted May 6, 2013 Vw rule did you buy a mk2 golf one? Can you update this thread after you have done it please? Would be very useful for all I am sure. Cheers. Edd Quote Share this post Link to post Share on other sites
vw rule 19 Posted May 7, 2013 Hello Edd, the MK2 Golf battery tray fits to the Corrado as the front chassis legs and inner wings around the struts, are very similar to the Golf and Jetta of 1988 to 1992 You just need to make a tinny adjustment to the front of the new tray where it fits against the front panel below the N/S/F head lamp. Hope this helps. Si Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 8, 2013 my advice is remove the front end {not even a 30min job} and cut the rott back sqaure in a nice rectangle shape with a cutting disc on a dremel, and cut a peice out from an old door or bonnet to put in its place maybe try and shape it if it needs it , weld it up and wax oil the crap out of the back side of it, you could buy a cheap welder , before you say " i cant weld" if you can draw then you can weld ,its just like dot to dot or if you want to spend the extra money and time on finding a genuine tray then go ahead but if it was me i idd rather splash out the funds on something that will get noticed/make a difference.. Agreed. Use it as opportunity to improve! Why not put a MK4 Golf steel section in and then you can bolt the lovely plastic battery carrier to it and use the equally lovely cover and power distribution panel etc etc.... I believe it's been done to MK2s a few times. It's so much neater and stops water being trapped under the battery and rotting the panel away. Quote Share this post Link to post Share on other sites
edd 0 Posted May 13, 2013 Apologies how did i miss your replies before i bumped this many thanks Kev and Si. Quote Share this post Link to post Share on other sites
vw rule 19 Posted September 19, 2013 Just in case anyone needs a new battery tray panel, they are now back in stock with VW Heritage. Part number is ( 191803105 ) Price is £22.60 http://www.vwheritage.com/vw_spares_Inner-wing-battery-tray-Golf-Mk2-left-191803105_act_shop.product_pID_47419415_lang_EN_country_GB.htm?crumbStartPage=1 And I think so is the O/S/F inner wing panel, this is similar to the battery tray side, but fits to the drivers side. Part number is ( 191803106 ) Price is £12.70 http://www.vwheritage.com/vw_spares_Inner-front-wing-repair-Golf-Mk2-Right-191803106_act_shop.product_pID_47419644_lang_EN_country_GB.htm?crumbStartPage=1 Hope this helps Si :thumbleft: Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted September 19, 2013 Sweet. I need a new tray. Description says mk2 golf. Will that definitely fit a corrado? Quote Share this post Link to post Share on other sites
vw rule 19 Posted September 19, 2013 Hello mate, yes it will fit the Corrado. I've had my new panel for a few months, just haven't had the time to weld it in yet. Rotten battery tray [ATTACH=CONFIG]75698[/ATTACH] New panel in it's rough place [ATTACH=CONFIG]75700[/ATTACH][ATTACH=CONFIG]75701[/ATTACH] Hope this helps Si :thumbleft: Quote Share this post Link to post Share on other sites
vw rule 19 Posted September 19, 2013 Some more photo's [ATTACH=CONFIG]75702[/ATTACH][ATTACH=CONFIG]75703[/ATTACH][ATTACH=CONFIG]75704[/ATTACH] These above I've just found on line. Again hope this helps. Si Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted September 19, 2013 That's great, thanks. I can treat myself come pay day! Quote Share this post Link to post Share on other sites
vw rule 19 Posted September 19, 2013 No worries mate, glad to be of help. Si :thumbleft: Quote Share this post Link to post Share on other sites
