Supercharged
3M Scotchcal Carbon Wrap - Slam Panel Bar??
Just wondering if anyone has used the above stuff to cover the bar that runs under the lights which is prone to stonechips?
£5 for a 10cm by 1.5m sheet of the stuff as opposed to £50 for a respray...
If its 3m it should be fine
Make sure you degrease it well , a wipe down with meths should be fine for that part , then a dry wipe down
One you put it on and its all trimmed in bake it down with a heat gun and you should be fine
I've got the transparent version on the rear boot opening,been on there 18 months,you really have to look for it !
Like that idea!
