twin45
a few breakers
A friend of mine is after a fuel pump from under the car and another from within the tank for a 16V. Can you help? (Hope this makes sense lol)
Thx twin45. Pipkin is the friend mentioned in my post, I'll let you deal with him directly.
Hi do you have a set of speedlines for sale? also sent u a pm with other parts needed.
Still have speed lines for sale
have also updsted now have 3 more in for breakin
Hi,
I see you now have a 9A for breaking. Does it have the external fuel pump in good working order?
Also, do you have a late grille with all tabs intact?
We have both in good condition and fully workin i drive car 1hr drive home with no probs £70 collected for both or £85 delivered cheers
Hi,
I need a short list of bits for '93 2.0 16v
r/h door with trim
r/h wing with trim
front bumper
grill
bumper 'skirt'?
r/h bumper bracket (on wing)
bonnet
bonnet catch (on bonnet)
front panel c/w bonnet locks
(will I continue?!)
radiator
r/h side rad cowl (inside)
PAS steel pipe
carbon canister
headlights & r/h headlight bezel, foglights & r/h wing indicator
and
r/h wing inner liner
Got any of those?
Car is some time off the road due to small incident and need to decide whether or not to rebuild or break.....
~~Thanks
W
Hand brake handle plastic and bulk head heat shield that covers ABS pipes? Do you have these pal?
Yer should have them black hand break sleave ?
Hi mate. Yeah black is what I'm after :)
Hi mate,
Do you have a the fuel pump plastic housing that sits underneath the car? Is it in good condition with no leaks as the two I have are both leaking from the joins. If so how much posted mate?
Bobby
Hi mate have you got a price for the part's I asked you about? And a couple of pic's if possible Thank's.
