tom_rob_89 10 Posted May 30, 2013 (edited) Hi everybody I'm having some ignition trouble, what happens is when I go to start the car all the red lights come on as normal but when I turn the key nothing at all happens with the engine. I've just had to bump it to get me home from work and once started its fine. Apparently there is something behind the barrel which will be the culprit but I just don't know what it is or called or where I can get one from lol :/ If anybody could give me some pointers that would be great :) Thanks Tom Edited May 30, 2013 by tom_rob_89 Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 30, 2013 Ignition switch, sometimes if the ignition switch is the culprit if you give the key a wiggle in the barrel it might start Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 30, 2013 Have you ruled out the starter motor? What your talking about is the ignition switch. Still available from VW (around the £25 iirc). Heres a guide how to change it but be warned, the little retaining screw is an absolute Barsteward to remove and refit!!! http://wiki.the-corrado.net/ignition_switch_replacement.html Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted May 30, 2013 Yeah sounds like the ignition switch to me. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 30, 2013 Some pics to help you out on here http://www.corrado-club.ca/forum/viewtopic.php?t=8617 Quote Share this post Link to post Share on other sites
tom_rob_89 10 Posted May 30, 2013 Thank you all for your replies I'm gonna try and get one tomorrow and get it on because I can't be bumping it every time I need to start it haha, until then I'm not looking forward to doing it at 6 tomorrow morning before I go to work but will definatly be giving the key wiggling a go before I push lol. Also thanks for the pics. Quote Share this post Link to post Share on other sites
JimyJonz 10 Posted May 30, 2013 I had the exact same thing a couple of weeks ago, was ignition switch as jon_vr6 said. Easy and cheap to replace just a bit fiddly Quote Share this post Link to post Share on other sites
tom_rob_89 10 Posted May 31, 2013 Well just got in it and the old wiggle trick worked lol Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 31, 2013 Well just got in it and the old wiggle trick worked lol Haha deffo the ignition switch then Quote Share this post Link to post Share on other sites
tom_rob_89 10 Posted June 2, 2013 I fixed it! thanks jon_vr6 for the link you posed, came in very helpful lol. Just mine hasn't got the bolts to loosen off to give you more room to work with so had to bend a screwdriver and was very fiddly but got there in the end haha, Cheers fellers, Tom Quote Share this post Link to post Share on other sites
Stonejag 10 Posted June 2, 2013 If you need to work around a broken switch, just disconnect the switch at the rear connector. Then crimp 4 spade terminals onto 4 wires and crimp all four wires into a single spade connector at the other end. Plug the four-ended spade into the middle row, middle pin, and plug the other four wires into the other four contacts. Can't remember off the top of my head which one is the starter, but plug the other 3 in first and then tap the starter pin to start it. No good for stealing Corrados with (as you still need the correct key inserted to turn off the immobiliser and unlock the steering lock!) but great for when your switch dies :) Stone Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted June 2, 2013 No worries mate glad you got it sorted Quote Share this post Link to post Share on other sites
