easypops
Another headlight loom thread
I have a updated loom I bought years ago, but as usual never got round to fitting it. I think I got it from eBay, but could of been on here?
I don't have any installation instructions but it looks fairly straightforward (famous last words)
I have 4 questions
1. The 4 spade fittings go where? Are they connected to the 2 plugs behind the passenger side headlight?
2. There is a wire that seems spare at the drivers side plug, it seems to be the grey one , which the wiki says is the sidelight one? Does it plug into the sidelight? If so where is the passenger side equivilent?
3. What do I do with the original plugs? Just leave them loose?
4. Does the lead with the fuses go to the + side of battery?
1. Into the original headlight connector (in the matching colour wires)
2. Spare wire goes into the drivers side original connector (grey one) should be a spade connector
3. Leave loose or cover them up to protect from rain
4. Yes
No worries mate when you feed the wire to drivers side i routed mine in front of the radiator (behind the front grille) so its away from any chance of the fans cutting into it. Also cable tie it in place
