daveb142
Power Steering Pipe
Hi there
I'm currently at the beginning stage of starting a 20vt conversion on my corrado.
I'm just wondering, what is the point in the metal power steering pipe that bolts through the front cross member? It looks as though it's a cooling pipe, however I don't see why the power steering fluid needs to be cooled? Was thinking of removing it and just running a straight pipe to the power steering pump. Then I could bolt the intercooler in front of the radiator.
Would doing this cause any problems? Does the pipe need to be there?
Dave
Yeah, it is a cooling pipe.
The reason for cooling it, is that the power steering fluid is compressed quite a bit by the pump - up to 80-100 bar or so(?) - and that creates a bit of heat. :)
hi mate what intercooler u useing and that pipe move it under so it gets air i cable tide to bumper the lower bit
Ah right fair enough! Might do what Marni said and just move it down under the cross member then :) A toyosports one off of ebay when I get around to purchasing it!
Cheers for your help guys!
