Micky fletch 10 Posted June 11, 2013 my drivers door wont lock everthing however my passenger door will what am i looking for, it used to all work fine Quote Share this post Link to post Share on other sites
Rams 0 Posted June 11, 2013 What do you hear when the car is locking and unlocking? Is there any louder vacuum sounds? First things I would be looking for is the vacuum line, sometimes they pop off. There's the pump in the boot, right hand side of boot behind carpet in a black soft padded box. Check this first and then check under the fuse tray, high up will be the orange vac line and see if this t connection is all connected and then finally, remove the door card and check the plug switch and wiring to the actuator. Have you tried turning the key in the door and seeing if it works or do you use a remote to control the central locking? Quote Share this post Link to post Share on other sites
Micky fletch 10 Posted June 11, 2013 Thanks for the reply I open with the key .there was a noise when opening up until a month or two ago. The passenger side works well fair play so I shall have a look at the weekend.thanks again Rams Quote Share this post Link to post Share on other sites
