timthetinyhorse
Hydraulic chain tensioner
Don't think that's necessary, cranking the engine without plugs in & fuel pump disabled ,for a while will ensure oil pressure at tensioner
There is a spring in there as well I think, enough to keep the chain on the chain wheel at cranking speed. It's sudden engine speed changes at relatively high revs which cause the chain potentially go sufficiently slack to jump. One long cranking session with the plugs out, until the oil pressure warning light goes out, and all will be well.
Best wishes
RB
