ger040 2 Posted August 3, 2013 Has any one any advice on how to remove the rear windows on a corrado i have tried using a wire as in the bentley manual but it will not cut the sealant so far after 3hrs of trying so far all i have managed is about 3 inches using a sawing action with the wire on the vertical b pillar although the manual tells you not to. i am thinking of heating a small blade and gently cutting the sealant from the inside but iam afraid of damaging the windows rubber seal as i have never seen what this looks like before being mounted. maybe i should cut my losses and arrange for a windscreen fitter to call and remove them for me before i loose my temper and end up doing some real damage!! Quote Share this post Link to post Share on other sites
Wesleyvr6 10 Posted August 3, 2013 I had a windscreen fitter take mine out a couple of weeks ago for my respray, he used the wire method but it did take him a while! It looked like a pain of a job too! Quote Share this post Link to post Share on other sites
