borarob 0 Posted August 14, 2013 anyone else get an annoying rattle from the boot area? plasticky sound, a bit creaky, seems to come from the parcel shelf. I have had this on both corrados i've owned and have never been able to successfully source its origin. Surely they all do this I can't have been unlucky twice! cheers! Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 14, 2013 Welcome to the squeaky club, I have the same as a lot of us on here . The usual suspects are , tailgate, these are designed to move with the car for flexibility so they can creak . Parcel shelf, try a bit of vasalene on the straps . The speaker pod bolts may need a tweak. Also the plastic covers on the door cards are prone to squeaking , also check spare tyre is seated properly and tool kit . A small amount of double sided tape or foam under plastics works as well . Oh and have a look at rear boot plastics , the list is endless really . Rob . Quote Share this post Link to post Share on other sites
tony_ack 0 Posted August 14, 2013 I'm still trying to get to the bottom of my last couple of knocks and squeaks, but as above the tailgate area is notorious for squeaks and rattles. I'd get yourself some black sticky felt from Hobbycraft (comes in A4 sheets) and some cloth loom wrap (useful for insulation between plastics as well as wrapping looms) and put it anywhere where plastics might be rubbing. Try looking at: Adjusting the boot catch height and adjusting rubber 'stops' under the bottom corners of the tailgate. Check tailgate alignment too. Spoiler (is it loose/is there any play?) Tailgate plastics - particularly the top corners where the side trims meet the top trim Parcel shelf - are the foam bits on the tailgate plastic present which hold the shelf still there? lube the parcel shelf straps, but make sure it's something that won't destroy the rubber Are the tailgate struts secure? Cloth wrap the wiring loom in the tailgate and also in behind the c-pillars (include the sunroof drains in this too). Don't forget the wiring to the rear speakers and the boot light. Are the parcel shelf supports fully secured? Make sure all clips on the c-pillar trims are present and that the fixers aren't broken Check for rubbing/missing foam insulation between parcel shelf supports/c-pillar trims and rear door cards Check rear door cards for rubbing on window 'ledge' Make sure all rear door card clips are present If you have leather, check the rear seats for rubbing against the plastics. Make sure rear hump is secure. Check space saver and tools are secure Is the foam above the headlining still present? Replace it if not Check the back of the sunroof cassette is secure Check rear strut top mounts are secure Quote Share this post Link to post Share on other sites
GusPW 0 Posted August 14, 2013 mine does this as well. I think the rattle on mine is the parcel shelf jumping because the foam bits on the tailgate fell off (didn't know where they came from at the time) and the squeaking is the rubber pins that it hinges on moving slightly when the shelf jumps. haven't got around to sorting it yet though Quote Share this post Link to post Share on other sites
borarob 0 Posted August 14, 2013 thanks for the replies guys, i'll work through the lists. i just thought it was strange that both i've had have made the same sound! Quote Share this post Link to post Share on other sites
scarlet_vr6 0 Posted August 14, 2013 I'm sure mine rattles and squeaks too but I can't hear it for all the rattles and squeaks from the dash. Another job added to the list! Quote Share this post Link to post Share on other sites
tony_ack 0 Posted August 14, 2013 (some) dash rattles: Badly fitted radio/loose cage Loose wiring (cloth wrap the looms) Broken/missing spring latches on controls/warning lights (e.g. ABS light, foglight switch, etc) Broken tab on ashtray holder Broken tab on ciggy lighter holder Missing rubber block in steering wheel cowling Loose/missing screws anywhere Missing fusebox clips Alarm wiring/boxes! Glovebox trim (the bit that covers screws when you open the the glovebox Glovebox rubbing against the dash (hobbycraft felt!!) Glovebox door All of the glovebox really Broken clips on gear lever surround Missing spring clips in dash vents Loose change/stuff in cubby holes/glovebox Badly secured spoiler module/factory immobiliser box Broken screwholes on centre surround (you can usually get away with 1 or 2) Quote Share this post Link to post Share on other sites
scarlet_vr6 0 Posted August 14, 2013 Thanks Tony. I'll have to work down that list! Some are definitely ok, but I'm sure that the glovebox is a major culprit. That tends to creak a lot so will have to pay some attn to that I think. Quote Share this post Link to post Share on other sites
borarob 0 Posted August 15, 2013 Hurrah. It was number 3 on Tony's list. It was the piece of trim above the rear window, wasn't on properly. I have now put double sided sticky foam along it and pushed it down properly into position. No more rattle, not even when the subs in the boot are at full chat. Another little job that can be ticked off :-) Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 15, 2013 scarlet_vr6 said: Thanks Tony. I'll have to work down that list! Some are definitely ok, but I'm sure that the glovebox is a major culprit. That tends to creak a lot so will have to pay some attn to that I think. I have the same problem , no matter how much foam or Velcro strips I use it still squeaks , doesn't help that I don't have a head unit so no music to drown it out ! Quote Share this post Link to post Share on other sites
