Captaincook 0 Posted May 14, 2004 Im lowering the car, using new standard shocks, I just would like to know your opinions on this set up. The springs are Spax, and drop the car 35-40mm. Quote Share this post Link to post Share on other sites
dubbprince 0 Posted May 14, 2004 well i'm running Boge gas shocks and lowered springs from GSF i believe...the ride is a bit firm but then again i do have 17's. I think it'll be fine just as long as you don't go lower than 40mm on std shocks or they might bottom out :wink: Sanj. Quote Share this post Link to post Share on other sites
Si B 0 Posted May 14, 2004 Std shocks with shorter firmer springs tend to give a slightly choppy ride. The springs you suggest are not too extreme so this won't be too serious. Uprated dampers would however be preferable to std as the pistons are shorter (so the springs don't drop out of place) and the damping firmer. This will greatly improve the handling and reduce the chop. Budget uprated dampers are not that much more expensive than std items. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 14, 2004 It's not ideal, cos they might have variable damping rates, which means that running lowered puts you into the "stiffer" damping range of the shock by default. Dunno, it all really depends on the details of the damper. If the manufacturer says they're ok to be used with the lowering that you're running, then it'll probably be fine. 30mm or so isn't a big drop anyway, so isn't a big deal, I think. Quote Share this post Link to post Share on other sites
Bally 0 Posted May 14, 2004 I ran 55mm springs on OE shocks with 17's & after a while the ride was crap! go for the best setup you can afford IMO.. Quote Share this post Link to post Share on other sites
