g60bv 0 Posted May 14, 2004 might seem an easy question, i'm looking to put rear passat handles on, i understand they will need some fiddling to work but which year of passat do i need.? i thought 91'.? :roll: Quote Share this post Link to post Share on other sites
h100vw 0 Posted May 14, 2004 Yeah my mate says you need the latch mechanism too. Disable the child lockthough!! Gavin Quote Share this post Link to post Share on other sites
MoonlightVR 0 Posted May 14, 2004 might seem an easy question, i'm looking to put rear passat handles on, i understand they will need some fiddling to work but which year of passat do i need.? i thought 91'.? :roll: Basically the grille-less fronted Passat. F-reg to K reg. Quote Share this post Link to post Share on other sites
randal 0 Posted May 14, 2004 Just got mine fitted about 15 minutes ago. You might have problems getting the whole lot to play ball. I ended up having to bend the lever on the lock mechanism up about 3-4mm, and twidling the lil' white plastic bell end on the handle down a fraction to meet it. Then had problems with the internal lock push, more twiddling with the white thing et voila! You gotta colour code em, they look wicked 8) Quote Share this post Link to post Share on other sites
Phil K 0 Posted May 15, 2004 .... plastic bell end on the.... :lol: :lol: :lol: Sorry very childish of me :oops: Quote Share this post Link to post Share on other sites
DaveStorm 0 Posted May 15, 2004 He he havn't heard that for years :oops: :) Quote Share this post Link to post Share on other sites
randal 0 Posted May 15, 2004 Couldn't think of another name for it! Seems to work pretty well. I ended up calling it someone else when I dropped one of them into the door cavity though :roll: Quote Share this post Link to post Share on other sites
g60bv 0 Posted May 15, 2004 cheers guys i'll order some up, ha ha ..you said bell end... :lol: Quote Share this post Link to post Share on other sites
chris CORRADO 0 Posted May 15, 2004 i was called a bell end today LOL :lol: and yeah fitting them is cool nothing hard you just have to bend a bit of metal... i did mine colour coded and there are proper BLING mental :mrgreen: Quote Share this post Link to post Share on other sites
dubbprince 0 Posted May 17, 2004 i thought its a straight forward fitment? is it the striking rod your bending? does your central locking still work ok? Where did you manage to get them from? i've been qouted £20 a side for the lock mech and handle 2nd hand. Sanjay. Quote Share this post Link to post Share on other sites
Den_VR6 0 Posted May 17, 2004 Local breakers yard - £20 for the locks and handles both sides. Drill the pin out which holds the child lock switch and bend the release striker up about 3mm, straight swap other than that. Quote Share this post Link to post Share on other sites
randal 0 Posted May 17, 2004 Yep central locking still works, only after you get the striking pin right though. I think that's what was wreaking havoc with mine, got that right and the c locking played along too. HTH randal Quote Share this post Link to post Share on other sites
