VR6 Lee 0 Posted September 14, 2013 Just had a spare key cut for the rado at timpsons and got quoted £50 to get the immobiliser coded in my new key.... Jesus Christ... Any better places Quote Share this post Link to post Share on other sites
tony_ack 0 Posted September 16, 2013 I got a key cut and coded at Harewood House a couple of years ago for about £25-£30 iirc, including the blank. That's probably the figure you should look at? The key snapped a few months later (luckily not in any locks), so I just swapped the transponder over into a new blank and got it cut at an independent. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted September 16, 2013 if you have an old key you might be able to split the plastic apart & remove the coded chip so as to put in the newly cut key ;) i found this out when i changed my ignition barrel 2 years ago - when i ordered it VW assured me the keys werent coded but they definitley are Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted September 16, 2013 I only have one key with code thing in it Quote Share this post Link to post Share on other sites
Dox 31 Posted September 16, 2013 If you have an aftermarket immobiliser fitted you could just tape the original key inside the ignition lock cowling and have another key cut. Plenty of engine transplants have the factory immobiliser defeated anyway. Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted September 16, 2013 If you have an aftermarket immobiliser fitted you could just tape the original key inside the ignition lock cowling and have another key cut. Plenty of engine transplants have the factory immobiliser defeated anyway. Think my bro has this done. I want a separate key though Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted September 16, 2013 Find a local auto locksmith, should be doable for Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted September 16, 2013 50-70 to get coded Quote Share this post Link to post Share on other sites
