rado mc
Many more random parts and bits added
All from a 1990 1.8 16v.
Parts in this bit are located in Bradford, west yorks and for collection.
postage sized items are further down.
If you see anything else in the pics thats not up just ask.
Gray chequered back bench both uppers - £10 also have lowers but would need a clean.
Rear panel/skirt ideal for cutting/replacing rust £20
Gray handbrake tunnel sections £10
Front wheel arch liners £20
Gray dash trays £5 each
Headlining £10
Sunroof mech tilt only £20
Gray boot carpet £5
Fuel tank £10
Drive shafts £10 each
Front subframe with power steering rack etc £60 (can seperate). Also have rear subframe.
Engine bay and dash loom with fuse box. If anyone is after certain connectors and a length of wiring etc let me know and i'll cut and post for few quid.
Prices below inc posting or collection from Preston for these below.
Also have Brake master cylinder and servo's.
The clutch cylinder from the bulk head/behind the pedal (not gearbox slave one)complete with pipe - £35
Gear stick and selector cables. £35
power steering pump £28
Tailgate wiring thingies :| £6
Fuel delivery pipes to fuel dizzy £6
Wiring loom for passenger door window.? £5
Cheers.
Edited by rado mc
The larger parts are over at my inlaws farm and not with me, hence collection only and two locations, so I'm not always available to sort it out.
If you want to arrange a courier for collection there's always someone in that i'm sure can tape and bag em up.
Just let me know.
Andy.
the brake msaster cylinder bolts ot the brake booster that connects ot the brake pedal inside the car.
on the firewall there is a bracket that secures the booster assembly to the car.
