_Meth 0 Posted September 19, 2013 Ok so turns out I have a huge amount of spare bits for the Corrado in my Garage that I simply do not have space for anymore. I will be adding more bits & bobs as I go through it all but listed below is what I have, everything set cheap because I just need it gone now; Rear bumper: £25 ( Currently in dragon green I believe but has some flaking from previous paint job so will need sorting - it is also wrapped up in postage ready plastic ) Sunroof frame: £15 ( The frame that bolts into the roof, that the sliders and everything attach too. Good condition, worked fine before I swapped out for moonroof - nice and straight ) Sunroof top panel : £15 ( The top panel that is painted to match the car - currently in Tornado Red but a bit faded as you would expect ) 1.8 16v KR ECU: £40 ( This also has the key signal thing bolted to the plate too. All in working order, was running my 16v absolutely fine! ) 1.8 16v Rear brake callipers & pads: £30 ( So with this you get both rear callipers with pistons pushed back (so no need to worry about windback tools), about 6 different pads I think with 30% - 70% material still left on them, pad backing plates, pad springs, and also the two lines on both of the callipers ) - these were working fine on mine but I swapped them out for MK4 rears the other month. ) Throttle cable I believe is for a 2l corrado : £10 ( basically does not fit the 1.8 16v - brand new in packaging from TPS. ) Complete set of G60 front brakes: £50 ( Pattern Front pads & discs brand new unopened in box ) I cant remember the rest at the moment, but will pop back out soon and double check for some more. Quote Share this post Link to post Share on other sites
vw bobby 10 Posted September 19, 2013 The G60 brakes, is that the hub and caliper or just the disc's and pads? Quote Share this post Link to post Share on other sites
JEZR 10 Posted September 19, 2013 Looking for a VDO unit if there's one nesting in there? Quote Share this post Link to post Share on other sites
stevec14 10 Posted September 19, 2013 Hi Brake dust shields for corrado G60 (front and back) and suspension(what you got)? I have coilovers at mo and don't really like the ride. Thanks Steve Quote Share this post Link to post Share on other sites
_Meth 0 Posted September 19, 2013 G60 Brakes are brand new Discs & Callipers - not a conversion kit, just the service items. 4 stud 288mm discs I believe and pads to match. No dust shields kicking around and I think I chucked the original shocks I had at the front before fitting my coilovers - I will double check for you though tomorrow! If I still have them, then they were fully functional a year or so ago when I removed them - but they will definitely need a good cleanup! VDO Unit? Quote Share this post Link to post Share on other sites
2sheds 10 Posted September 20, 2013 Throttle cable please!! ;) Quote Share this post Link to post Share on other sites
vw bobby 10 Posted September 20, 2013 (edited) Hi Meth, What other parts will I need for the conversion to g60 brakes, is it just the carriers? I have a 1991 corrado 1.8 16v? if so I will take these? Cheers Bobby Edited September 20, 2013 by vw bobby Quote Share this post Link to post Share on other sites
_Meth 0 Posted September 20, 2013 Sheds - PM Sent Bobby - I think you need callipers & carriers, but I converted mine so long ago I cant remember! Quote Share this post Link to post Share on other sites
vw bobby 10 Posted September 20, 2013 Sheds - PM Sent Bobby - I think you need callipers & carriers, but I converted mine so long ago I cant remember! Meth did you not say that you have the calipers? Quote Share this post Link to post Share on other sites
_Meth 0 Posted September 20, 2013 No, I have rear callipers and more pads than you can fit in them. Front wise I have a complete set of pads & discs. Quote Share this post Link to post Share on other sites
JEZR 10 Posted September 20, 2013 VDO Unit? Oil & battery meters that sit in the hole in the centre console. I think they were an under added add on and I think mainly on US spec Vrs! Ever hopeful... Quote Share this post Link to post Share on other sites
_Meth 0 Posted September 22, 2013 Aha thats what I thought you might be getting at... sadly no. Quote Share this post Link to post Share on other sites
